Cannot delete previous version
Well. The title says it all.
Very excited to test this plug-in. First thing that happens, it crashes my max. Then I realize I should update it and now my pc won't delete the .dlo file. Or... it's stuck. Don't know if this has happened for others. Can't find a post, so I thought I'd share my findings.
Dell Precision T5600
2xXeon E-2630 24 CPUs ~2.3Ghz
GTX 1080
32GB Ram
Win 10 Pro
Hi, please make sure no other copies of 3dsmax are running still. Check your task manager for running instances of 3dsmax.exe.
If you continue to get the crash in the latest version, please enable forced file logging outlined here:
http://docs.tyflow.com/feedback/bugs
And send the generated log to [email protected]. Also let me know if you're using English windows and English 3dsmax, or versions of another language.
(04-17-2019, 05:49 PM)tyFlow Wrote: Hi, please make sure no other copies of 3dsmax are running still. Check your task manager for running instances of 3dsmax.exe.
It seems to have fixed itself after a couple of reboots.
I had the plugin installed on Max 2017-2020, just to see if they all worked. I have not managed to delete them all(it was version 16012_VRayNEXT) eventually. Now I have installed the newest only for 2019 and it seems to be working fine.
I have English windows, max and no instance of max was active at the time.
Thank you for your quick response!
GTX 1080
32GB Ram
Win 10 Pro
