Hey there,
I have a simple scene, I tycache the scene, vraydistancetex by default works fine on tycache, but if I simply swap the far and near color ro create an inverse effect, it doesn't work, forget about swapping colors, if I inverse the distancetex through output node it still doesnt work.I have already shared it in vray forum, and now sharing the file with you.
this problem is very specific with tycache, it works fine with tyflow geometry.
I am attaching the max archive, please check
tocheck_01.zip (Size: 2.36 MB / Downloads: 284)
Thank you
Nayan Bodawala
Well the issue is also happenning with tyflow geometry also.....and issue is happening with tyflowGPU only.....
Thank you
Nayan Bodawala
