02-28-2024, 03:01 PM
(This post was last modified: 02-28-2024, 03:02 PM by christierney.)
Hi guys,
I would like to sweep a change of material ID through my array of voxel -generated particles so that I can swish the effect back and forth several times.
What I have found is that I can move [Box 1] through the particles and it will change their material ID to 2 quite nicely.
I then move [Box 2] through and it will switch them back to 1 again.
It works pretty well for the first two cycles, however however when I try to move [Box 1] through again I expected it to run the test again, however materials will not switch - here's a screencap of the materials switching very nicely, then refusing to change:
https://youtu.be/tSRP18v8n2c
My tyflow setup looks like this :
![[Image: 0NHRfIi.jpg]](https://i.imgur.com/0NHRfIi.jpg)
I have tried a few different methods - at the moment the only thing that might do it is daisy chaining multiple tests for Box 1 and Box 2. I do have the timing for the tests set to "continuous" which I assumed would apply them on a per-frame basis, but I am not sure.
If anyone is generous enough to look at the MAX file, it's here:
https://www.dropbox.com/scl/fi/9n5dqes2l...qdol7&dl=0
Chris
Chris
