export node file name error
in the export node, there is a text box with "particles_"  in it.
if i try to browse to a folder, only the options "open in explorer" and "browse to" are available.   both of them say "path not found" when i click them
if i hit export i get a similar error.
i tried manually typing a path in the text box, but it still gave an error.
the only way i managed to get it to work was to manually create a fake particles_.prt file in a folder,  type the path to it in the text box.   then i could use the browse/reveal options, and exporting worked.
That's quite bizarre....does your default 3dsmax scenes path have any special characters in it?
