03-28-2024, 03:50 AM
tyFlow v1.108 is up!
https://pro.tyflow.com
* added mesh skeletonization mode to tyMeshToSplines modifier
* added rotation limiter to Rotation operator
* Object to VDB and Particles to VDB operators can now instantiate a velocity grid from input object/particle velocities
* tyFlow instances now support curved motion blur when rendered with VRay CPU (users should ensure they are simulating with a small enough timestep, and have subframe caching enabled, in order to see the intended result of motion blur in VRay CPU computed with more than 2 geometry samples)
* added "random order" option to Birth Surface operator
* added "align to travel direction" option to Branch operator
* fixed an issue where the Object Bind operator could crash if input geometry had changing topology
* simulations can no longer auto-reset during export
* fixed an issue where the Export Particles operator could fail to export cloth/spline meshes properly if the scene tick count was not evenly divisible by the sim time step
* fixed an issue where the Branch operator's spread value was not rotating branches around the right axis in all situations
