04-04-2024, 11:42 AM
The following situation has happened in my simulation, in the stack I have a birth node, an array, a form node and a visualization node, I would like to animate only the array, to make a repeating circle of the forms constantly moving from A to B; however, when I try to animate the offset parameter it does not record the movement until it marks the four keys, but the movement does not. I'm using the latest version of Tyflow and I've tried it in different versions of Max. In fact, the array could have more instant options or copy presets, like Maya's Mash or C4D's Cloner, with grids, radial, etc... If anyone can help me thank you.
