[Error] tyFlow RENDER v1.111
Video
Hi, everyone.
Today I was fascinated by the new AI generations and wanted to try them out as well.
I downloaded tyFlow RENDER, installed it, and now I have a problem with the generation.
What could I have done wrong during the installation?
I'm not sure if you're the same user who posted a similar question on discord...but either way, if you can send me both the tyDiffusion settings file and ComfyUI workspace from the setup, I can look into it. Looks like maybe a special character isn't being escaped properly in my JSON parser (are you using non-English windows?)...shouldn't be too hard to diagnose once I get those files.
Workspace can be exported from the tyDiffusion presets menu.
tyDiffusion settings file is here: c:\ProgramData\tyFlow\tyDiffusion\tyDiffusionSettings.xml
Video
(07-03-2024, 12:57 AM)tyFlow Wrote: I'm not sure if you're the same user who posted a similar question on discord...but either way, if you can send me both the tyDiffusion settings file and ComfyUI workspace from the setup, I can look into it. Looks like maybe a special character isn't being escaped properly in my JSON parser (are you using non-English windows?)...shouldn't be too hard to diagnose once I get those files.
I don't have your discord Sad
I attached you the file "tyDiffusionSettings" and additionally, video windows in 3DsMax.
I don't seem to have any non-English windows
Will this files be enough?
.rar   tyDiffusionSettings.rar (Size: 5.78 KB / Downloads: 177)
Hello
i dont know if it s the same pb but it looks like
my Comfyui works fine i can play with it,but when i clic on "generate image" in 3dmax  ( 2023 )
i have this in consol :
got prompt
Error handling request
Traceback (most recent call last):
  File "C:\ProgramData\tyFlow\tyDiffusion\Tools\python\lib\site-packages\aiohttp\web_protocol.py", line 452, in _handle_request
    resp = await request_handler(request)
  File "C:\ProgramData\tyFlow\tyDiffusion\Tools\python\lib\site-packages\aiohttp\web_app.py", line 543, in _handle
    resp = await handler(request)
  File "C:\ProgramData\tyFlow\tyDiffusion\Tools\python\lib\site-packages\aiohttp\web_middlewares.py", line 114, in impl
    return await handler(request)
  File "C:\ProgramData\tyFlow\tyDiffusion\Engines\ComfyUI\ComfyUI\server.py", line 42, in cache_control
    response: web.Response = await handler(request)
  File "C:\ProgramData\tyFlow\tyDiffusion\Engines\ComfyUI\ComfyUI\server.py", line 454, in post_prompt
    json_data =  await request.json()
  File "C:\ProgramData\tyFlow\tyDiffusion\Tools\python\lib\site-packages\aiohttp\web_request.py", line 686, in json
    return loads(body)
  File "json\__init__.py", line 346, in loads
  File "json\decoder.py", line 337, in decode
  File "json\decoder.py", line 353, in raw_decode
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 44 column 10 (char 993)
this version looks amazing by the way , bravo !
my tyDiffusion settings file and ComfyUI workspace in zip here
.zip   clement3d_TyDiffusion.zip (Size: 6.8 KB / Downloads: 162)
Hello!
I have the same issue. Pressing "Generate", I receive an error:
got prompt
return loads(body)
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 44 column 10 (char 829)
Thank you, I believe I see the issue - numbers with decimals (ex: 5.0) are being saved with commas (ex: 5,0) to the json format, which is messing with the parser. I'll try to get a fix out asap.
(07-03-2024, 01:27 PM)tyFlow Wrote: Thank you, I believe I see the issue - numbers with decimals (ex: 5.0) are being saved with commas (ex: 5,0) to the json format, which is messing with the parser. I'll try to get a fix out asap.
Thanks ! Smile
I think I have the same issue, the error is the same and here in Italy we use commas for decimal numbers Shy
edit: solved from windows settings
Confirming that by changing the Decimal Symbol to a dot (.) fixes the issue and tyDiffusion works with no errors.
Control Panel > Clock and Region > Region > Additional Settings > Numbers Tab > Decimal Symbol = select the dot/fullstop
Theodoros
Redownload the latest build and this issue should be fixed.
hello
it s working now Smile
thanks
