reform effect
Hi.
Here is the scenario:
let's say we break a cup, and after a time period we need all the broken pieces get back together and form the cup again.
I used to get this effect in pflow box#3 by getting the position and rotation data from the initial state of the particles , then feed it into the "find target" operator and finally using a "go to rotation" operator I ended up with a cool reform effect.
now how can I get the same effect using Tyflow? I'm kinda thinking I need to use "particle properties" operator but I don't know how. I get things but everything gets messy and not working as expected.
By the way TyFlow is awesome. thaaaaaanks Smile
Custom properties -> save TM to channel of your choice.
Find Target -> specify the channel you want to use as the target.
Essentially exactly workflow as PFlow, minus the Box#3 shenanigans.
(04-20-2019, 02:46 AM)tyFlow Wrote: Custom properties -> save TM to channel of your choice.
Hi, just tried but…. can you make this as an exemple.   Big Grin
Damn it man..works like charm...and it was really easy to setup...box3 was just a nightmare...
Tyson don't join the army or you will make horrible weapons with that brain of yours Smile)
But seriously thanks a lot man. I will never get back to pflow Smile
(04-20-2019, 04:26 PM)esisb Wrote: Damn it man..works like charm...and it was really easy to setup...box3 was just a nightmare...
Hi esisb, could you share you nodes ? I can't manage to make particle move back to origin    :-(   (please)
Hi.yeah sure. Actually I'm gonna make a quick tutorial on youtube n I'll share it here soon.
Thank you !!!! :-)
https://youtu.be/wHkkbE4CHeQ
(04-20-2019, 10:07 PM)esisb Wrote: https://youtu.be/wHkkbE4CHeQ
Thank you , very professionnal   Big Grin
I understand now why it didn't work for me ! cheers
