07-08-2024, 07:37 AM (This post was last modified: 07-08-2024, 07:38 AM by Arshi.)
Dear Tyson Ibele,
I'm facing an error with TyFlow: "Error: could not move tmp file to target location (code:21)." Has anyone else had this problem? Any solutions would be greatly appreciated!
Thanks!
During download, files are temporarily saved to: [tyDiffusion root]/Models/_tmp, then once the download completes successfully, they're copied over to the specified external path. You'll see that error if an issue occurs during that final copy operation.
What is your ControlNet external path set to? Do you have enough space on that disk for the file? Are any other permissions issues preventing the file from being copied? First thing I'd recommend is making sure the external path is set to a drive with enough space for the file, and that you have copy permissions in that folder (you can try running Max as Administrator to solve the latter).
