TyPush - Add a scale option to the Push Element
Do you think it could be possible to add a scale thickbox (Relatively link to the push element amount ? Or a separate slider ?).
So as the element are far away, the scale would be 0 and when the element are at the original place, they have a scale of 100%.
This would be a very nice add to make a lot of elements popup without seeing them from the beginning and dynamically link to the Push amount ?
Thank you
Why not switch to tyFlow itself for this kind of thing? You can set the simulation mode to "history independent" so that no simulation actually happens (it'll operate more like a modifier or static object), then use various operators to achieve the same thing. See attached.
.max   spreadScale.max (Size: 656 KB / Downloads: 277)
Yes, i could do that too.
But the TyPush Modifier it a lot faster to set-up and to paste over multiple object for quick animation and a little less messy to organize and transfer over teamwork.
Have you tried the "transform elements" module in the Data Channel modifier? It seems to offer a way to scale elements in the way you want (I haven't tested it myself)...
Yes i have tried it. Smile It also work
But again, having a simple checkbox to have the scale link to the Push Element amount would be so much easier to set-up. ^^
