tyFlow v1.114
tyFlow v1.114 is up!
https://pro.tyflow.com
* added checkbox to enable/disable all active LoRAs
* added AnimateDiff beta schedule parameter to tyDiffusion
* added option to choose output directory for tyDiffusion source/output images
* added layer selection to tyDiffusion render sources
* added minimize button to tyDiffusion window
* fixed an issue where running a single tyDiffusion preprocessor would run the initialization routine of all other preprocessors as well, leading to things like unwanted render updates if another preprocessor had the VFB as its source
* added automatic ComfyUI source image mode to tyDiffusion Misc settings (switches to raw image mode when animation enabled, rather than using base64 strings - prevents issues with errors occurring while generating longer animated sequences)
* fixed a regression where tyDiffusion wasn't properly using video input when exporting animations
i'm trying to download some diffusion models from tyDiffusion UI models section but nothing happens, I also opened tyflow's hugging face page to download the models manually but nothing is there, can someone please help?
Consult the FAQ about downloading from tyDiffusion's UI: https://docs.tyflow.com/faq/AI/#nbsp-whe...at-do-i-do
As for the HuggingFace repo (https://huggingface.co/tyDiffusion), not sure what you're referring to. Click any of the datasets, then click "files and versions" and all the files are there.
(07-16-2024, 02:37 PM)tyFlow Wrote: Consult the FAQ about downloading from tyDiffusion's UI: https://docs.tyflow.com/faq/AI/#nbsp-whe...at-do-i-do
that was very helpful, thank you so much
