tyFlow v1.115
tyFlow v1.115 is up!
https://pro.tyflow.com
* added Birth ForestPack operator, for converting ForestPack instances to tyFlow particles
* added "scale along spline" option to Birth Spline operator, with curve control, for controlling scale of born particles along length of spline(s)
* tyDiffusion Misc settings have been re-arranged, so that live preview and frame extraction settings have been moved to Advanced engine tab, and image output settings will be saved/loaded with preset files (existing presets need to be resaved for this to take effect)
* PhysX Shape operator will now auto-repair transforms of particles with negative scale, which prevents collision hull issues for particles with negative scale
* if multiple Export Particles operators (in tyCache export mode) are present in a single flow, the Deadline export option will now ask if you want to group the export jobs together (grouping jobs together allows them to share the same RAM cache, potentially speeding up export if they are exported from the same machine)
* added "multiply by curve along spline" parameter to tySplineMesher extrude settings, for multiplying extrusion amount by curve mapped to spline length
* output PNG images auto-saved by tyDiffusion will now include both the ComfyUI workflow and tyDiffusion XML preset in their metadata. PNG files containing a tyDiffusion XML preset can also now be loaded by tyDiffusion
* added sampler/scheduler overrides to tyDiffusion upscalers
* all places where tyFlow previously offered a "relative to mass" option, a "relative to property" option has been added instead with more options
* added "only if first child" option to PhysX Bind "bind to parent" mode
* fixed an issue where "only if first child" option in Particle Bind operator wouldn't work if "bind to siblings" was disabled
* fixed an issue that could cause the tyLibMtl to crash Max
* fixed a regression that caused tyPreviews fps multiplier to stop working on image sequences
* fixed an issue where the [...] menus of the image output paths in the Misc tab of the tyDiffusion UI weren't working properly
* fixed an issue where the tyParticleSkin modifier, imported through a tyActor, wasn't properly interpreting pivot offsets on driver particles
* multifracture cutting planes will now take into consideration per-axis noise affect parameters when noise is in plane space, resulting in smaller plane expansion when some noise affect parameters are less than 100%, leading to faster slice calculation times
* fixed a regression where tySplineMesher "taper by specific length" mode wasn't working properly
* renamed tySplineMesher "taper by specific length" mode to "taper from start" and also added "taper from end" mode
