tyflow export particles as instances?
How can export particles >objects but as instances not as copies?
PS I found reference objects as instance but they are chosen at random (Reference Objects: exports particles as duplicates of a reference object taken from the listbox (chosen at random).)
Why cannot tyflow replace Birth object with the right reference object as instances
Export Particles will already export particles as instances of each other for any particles that share meshes (are instances in the flow).
(08-09-2024, 12:24 AM)tyFlow Wrote: Export Particles will already export particles as instances of each other for any particles that share meshes (are instances in the flow).
Thank you
When  i export as objects even the same objects become copies and not instances for some reason.  And they clog vram.
The particles have to be instances within the flow. That means more than 1 particle need to share the mesh.
If you're trying to have your exported particles be instances of the original objects you imported using Birth Objects, that's not currently possible. Once particles are imported they are completed decoupled from their source object.
