tyFlow v1.117
tyFlow v1.117 is up!
https://pro.tyflow.com
* added particle-to-particle boolean methods to Boolean operator
* you can now load images (as masks) into the tyDiffusion detailers paint mask dialog box
* tyDiffusion detailers can now apply existing styles/LoRAs to result
* added various QOL improvement to tyDiffusion detailers. Note: "Remove this detailer" button removed - detailers can now be removed by right-clicking their button and choosing "Remove"
* added face/vert normal modes to tyConform transfer/temporal sample parameters (face mode can reduce artifacts in some cases)
* fixed an issue caused by the Birth Objects operator, that could cause Max to crash during scene reset
* fixed an issue in the PRISM engine where performing subtraction operations on areas with coincident faces would leave holes in the resulting mesh
* fixed an issue that could cause tySelect in Mesh selection mode to run with very poor performance
* fixed an issue where tyDiffusion may not be able to see the ComfyUI root folder due to invalid syntax in python310._pth file
* all tyDiffusion internal strings changed to wide-character strings, to support non-English (ex: Chinese) characters in filenames, model names, etc
* fixed an issue where the tyConform modifier could crash, in temporal conform mode, when the source mesh has changing topology
* fixed an issue with the Boolean operator where particles whose entire mesh was subtracted (leaving zero retained faces) would display their original mesh
* fixed an issue that could cause some complex scene to take a long time to initialize during tyDiffusion generation
* fixed an issue where trying to save the color or depth channel from the viewport save menu would only save the diffusion result
* fixed some issues related to how tyActors calculate their clip playback percentages, which are then relayed to other operators like the Property Test operator (off-by-1 errors were resulting in desync between animation playback and Property Test results)
* Display Data operator's action animation data display mode will now display more information related to playback frame/percent for the current clip
* fixed an issue where default tySpiral interpolation curve was inverted
* fixed an issue where Export Particles was not properly assigning the last key on export objects, for particles that are to be scaled down when deleted
