tyFlow Render Version 1.117 not working in Max 2024.2 !!!
Hello good people.
I have just downloaded the latest version of tyFlow Render (1.117) and pasted the *.*dlo file inside the max directory, but it seems like not working or loading up correctly. Although, when I open max >Customization and Plugin Manager, I can see tyflow is loaded. My question is - did anyone else facing similar issue?
My Max version is 2024
EDIT WITH SOLUTION: I was trying to install the wrong version for my max 2024.2 and got the issue, but this time I have downloaded tyFlow V1.117 instead of tyFlow Render v1.117 and it worked fine for me. So best of luck anyone.  Heart
Seems like an issue with your Max configuration.
(08-10-2024, 02:53 PM)tyFlow Wrote: Seems like an issue with your Max configuration.
Thank You for your kind response on the issue. You might be right, it might some issue with my max configurations, but as far as I can understand and every other plugin and scripts loads-up correctly, I have doubts in my mind about tyFlow itself.
Still working on it to resolve the issue myself - all the best to me.
