Surface Test Possible Issue
G'Day Tyson
Just playing with the surface test and getting unexpected result with volume inside mode - see attached video
Regards
  Rob
Edit/update - If the particles birthed on the sphere vertices stay on the sphere and I disable the speed.  Then I move the cylinder over them, the test works as expected.
If I move the particles with speed and they are away from the birth sphere the test don't work.
.mp4   Surface Test Possible Issue.mp4 (Size: 3.81 MB / Downloads: 313)
It's expected.
Once you changed the test to volume outside, you immediately sent out all the particles to second event.. and they stay there.
So when animation is going on, all particles are in second event, and unable to detect anything (they are no longer in first event), unless you add another surface test to second event (where particles chilling and drinking beers. Smile )
Hope that helps
(09-15-2024, 09:34 PM)d4rk3lf Wrote: It's expected.
Hope that helps
I should have realized that !! - The deeh moment, is I did add it to 2nd event to test that, but forgot to pass it onto a 3rd event to see color change Smile - Sometimes lack of thinking happens Smile
