09-20-2024, 02:04 PM
G'Day Tyson,
I was working with the Array Operator.
Lets say you have a cube then birth obj from cube. Then use Array in circular mode. I made the assumption, that if I set my step size to a number divisible into 360, I would get an even distribution of spawned particles.
But there is always an overlap on the 1st and last particles and two are born on the same spot. EG: circular step 120 results in 4 spawned, 60 step results in 7 spawned.
I know I can use count mode and avoid the overlapped particles. Just wonder if this overlap is intended by you?
Thanks Tyson
Rob
Thanks Tyson
Rob
