09-24-2024, 06:46 PM
have a tyflow simulation with multiple events, 2 events named the same
I get a tyflow instance by `rt.objects() where the classof is `TyFlow`
In a debug view I see a list of tyEvents with names like `Event_003` based on the name of the event in the tyflow node view.
If I have two nodes named the same, lets say "Event_005"
if `show $` in the listener
I see 2 `.Event_005` attributes
using pymxs import runtime as rt
if I rt.getPropNames(node)
OR dir(node)
## Actual:
There is only 1 "Event_005"
## Expected
There should be 2 events named "Event_005"
My guess is that you are setting events as attributes of an object, there cant be more than one with the same value, but when I show $ I do see both events.
I am developing a tool and I have so far had to tell the artists using that "If you arent seeing what you expect in the list, check for duplicate naming"
Any help would be much appreciated.
OR dir(node)
## Actual:
## Expected
