tySplineMesher BUG
After setting the color settings in TY,
when I use tySplineMesher to Tube, the colors I set are displayed correctly,
but when I change to Mesh, the mesh changes to a broken color.
This makes the mesh option useless,
.zip   ty_or_C_02.zip (Size: 218.88 KB / Downloads: 274)
.mp4   2024-10-02 20-06-33.mp4 (Size: 8.83 MB / Downloads: 342)
That seems pretty odd - I will look further into it.
(10-03-2024, 02:20 AM)tyFlow Wrote: That seems pretty odd - I will look further into it.
I changed to CoronaRender to try it out.
I am happy to report that the results are correct.
Is this a problem with Vray? Very strange.
It appears to be a bug related to VRayBitmap sampling zero-area faces. If you switch filtering mode to Isotropic in your VRayBitmap texmap, the issue goes away. This also explains why there are no issues in other renderers.
I would suggest logging the problem with Chaos.
