10-07-2024, 04:21 PM
I apologize in advance for asking a basic question. I need help changing the starting frame of the simulation. I want everything to stay the same, just for the simulation to start later. I have a very simple setup that creates a chain:
Event 1 (longer chain) - Bith Objects, Phys Shape (Compound), Phys Collision (Mesh)
Event 2 (only one ring conected to chain in Event 1 with Phys Bind) - Bith Objects, Phys Shape (Convex Hull), Phys Collision (Mesh), Phys Bind (joint).
This chain behaves perfectly when simulation goes from 0-100, however, when I set the timeline to say 101-200, simulation falls apart. In that failed simulation I tried to set the timing in Phys Shape and Phys Bind operators instead of "on event entry" to frame 101-200. Tried all options from starting penetrations with no result. Is it possible to make the simulation look the same as starting from frame zero and how? Thank you in advance.
