Birth Object with "inherit material from object": possible to change material later?
Question
I have accidentally inherited a material in a birth object.
Can I change this later?
Whatever I assign now to the tyCache object, it does not react anymore on material assigned to it's material IDs in render.
Unfortunately it always looked right in the viewport, so I realized it only in the end Sad
In the tycache object itself, in the modify panel, under material overrides, uncheck load instance material.
Ah great, I should have looked there at first. Thanks
