tyFlow v1.120
tyFlow v1.120 is up!
https://pro.tyflow.com
* added tyCache modifier, for efficiently caching modifier stack mesh data (see docs for more info)
* added "Edge fracture (advanced)" mode to Multifracture modifier/operator for more advanced edge fracturing on concave meshes
* added spline optimization mode to tyOptimize modifier
* added tyMaterial modifier
* added UVW relax mode to tyRelax modifier
* added support for VRay 7
* fixed an issue that could cause the Optimize operator to crash when moving/dragging dependent objects in the scene
* fixed an issue where the tyFlow GPU device dropdowns weren't working properly
* fixed an issue where the Sort operator was not properly updating its internal ID-to-index caches, which prevented other operators from finding their post-sort targets properly
* fixed an issue where Multifracture edge fractures were mangling fracture mesh UVWs when "cull fractured meshes" was enabled
* fixed an issue where tyVAT exports were not accounting for object pivot changes
* fixed an issue where tyDiffusion viewport menu was visible in tyPreviews
* fixed a variety of issues in the Branch operator, mostly relating to how splay/spread values are applied and how the branch alignment transform is constructed
* tyFlow/tyCache particle interface data collation methods are now multithreaded, leading to faster render startup times when rendering millions of instances
* fixed an issue where conforming mesh UVWs with a tyConform modifier would produce an additive result
* fixed a rare issue which could cause the tyFlow floating license server to show an incorrect number of available seats and/or fail to activate
Is there any way you could add support for 3DSMax 2017? I can't go up to 2018 because I reply on a meterial addon that only works on 2017.
Thanks for any help!
Not possible, no.
That's alright I have 2023 it just runs kind of slow on my computer
I don't think he likes me Sad.
(12-10-2024, 12:52 AM)Kamuix Wrote: I don't think he likes me Sad.
Well.
You have 3DS Max 2023 but ask for 2017 support, just because it's more convenient for you?
That is kinda offensive imo. Smile
Well It's the way he responded. he didn't say something like 'Sorry i can't do that it would be too much work' Instead of what he did say which was "Not possible, No!"
Bottom line is he hurt my feelings
