I'm unable to figure this out.
I have a phoenixFD simulation.
I want to voxelize it and color it using the speed magnitude.
But phoenixFD and Tyflow seems to load velocity (vector) instead so I can't color nicely...
Is there a way to convert the vector to a magnitude float in tyflow? or... prehaps needs to be done in phoenix?
thank you.
solved it myslef.
Use a fluid propierties, load the phoenix velocity in channel "phvel"
Use a custop Propierties in GET mode to transfer Channel "phvel" to the "velocity" custom vector data.
in the mapping operator use "velocity magnitude"
thank you.
solved it myslef.
