Need urgent help with tycache
I have Tyflow Pro ver.1.123.
Issue is when I expport any Tycache. It just doesnt display in viewport. I tried with 3Ds Max 2023 and also in 3ds max 2025.
You can check the video. When I toggle display options, it displays for 1 frame and disappears after the playing.
I am in between project and I need tycache.
Video:
2025-01-26 19-54-58.mp4
-Raj
If you revert to an older build does the issue still occur?
(01-26-2025, 03:03 PM)tyFlow Wrote: If you revert to an older build does the issue still occur?
I downgraded to 1120 version but still same issue with tycache.
-Raj
-Raj
And same with version. 1118. It turns ON and OFF.
Its working now. I reinstalled GPU drivers. It was not working, even after updating. Then I deleted the cache and again created new cache and now its working.
Dont know what was the main issue.
Thanks,
Raj
Odd - glad you found the solution.
