ExportGroup in Particle Export does not work.
Particle groups are divided into 1 and 2 and then sent to a single event.
When I check in DataDisplay, they are properly separated, but when I export, they do not come apart.
Culling in Tycache is also not working.
I am recording a video for more information.
Is this a bug?
Thank you in advance for your help.
.mp4   2025-02-05 14-50-03.mp4 (Size: 28.34 MB / Downloads: 285)
If you enable group filters in your export, that won't have any effect on cloth being exported (only potentially the underlying cloth driver particles). Cloths themselves do not have group assignments (the groups applied to underlying cloth driver particles do not affect cloth or cloth export).
A workaround which would allow you to split up cloth after export would be to assign material IDs to cloths (different IDs per cloth), then use a tySelect in combination with a DeleteMesh modifier to split up cloth caches, select parts you need or don't need, then delete the rest.
