02-23-2025, 03:42 PM
not sure if a bug, but if you use a spline birth operator on a circle primitive, or an editable spline with an edit spline mod on top, and start moving verts about - then the flow isn't updated unless you manually refresh it?
If you collapse to an editable spline it works as expected.
Max 2022, latest TyFlow Build 1.123
Thanks,
Steve
Thanks,
Steve
