hello,
so this drove me nuts.
error messages in the message log windows when opening customize -> menu editor.
https://i.imgur.com/EzCGAHt.jpeg
after some testing i figured out it is tyflow (version 1.125 and 1.123 confirmed, i did not use v1.124).
when i remove the tyflow.dlo from the plugin folder that error message is gone.
when i put tyflow.dlo back in the plugin folder i get the same error message again. nothing else changed on my 3d max setup.
not a big thing in the grand scheme of things i guess but maybe something you want to look into.
3D Max 2025.3
Windows 10 22H2
Ryzen 5950x
64GB Ram
Code:
Loading configuration metadata resource file 'C:/Program Files/Autodesk/3ds Max 2025/en-US/CUI/3dsmaxMenus.mnx.res'.
Loading menu base configuration file 'C:/Program Files/Autodesk/3ds Max 2025/UI_LN/CUI/Default.mnxb'.
Loading menu base configuration resource file 'C:/Program Files/Autodesk/3ds Max 2025/en-US/CUI/Default.mnxb.res'.
Loading menu configuration file 'c:/programdata/autodesk/applicationplugins/advancedmodeling3dsmax2025/contents/cui/booleanmodifier.mnx'.
Loading menu configuration file 'c:/programdata/autodesk/applicationplugins/advancedmodeling3dsmax2025/contents/cui/arraymodifier.mnx'.
Loading menu configuration file 'c:/programdata/autodesk/applicationplugins/maxtoa_2025/maxtoa.mnx'.
Loading menu configuration file 'c:/programdata/autodesk/applicationplugins/retopology3dsmax2025/contents/cui/retopology.mnx'.
Loading menu configuration resource file 'c:/programdata/autodesk/applicationplugins/retopology3dsmax2025/contents/cui/en-US/retopology.mnx.res'.
Error: Detected 'GetICuiMenuManager()' call to incorrect menu manager within the NOTIFY_CUI_REGISTER_MENUS notification. Please make sure to use the menu manager pointer that is being passed as a notification param.
Error: Detected 'GetTopLevelMenus()' call to incorrect menu manager within the NOTIFY_CUI_REGISTER_MENUS notification. Please make sure to use the menu manager pointer that is being passed as a notification param.
Loading menu configuration file 'C:/Program Files/Autodesk/3ds Max 2025/UI_LN/CUI/3dsmaxMenus.mnx'.
Loading menu configuration resource file 'C:/Program Files/Autodesk/3ds Max 2025/en-US/CUI/3dsmaxMenus.mnx.res'.https://i.imgur.com/EzCGAHt.jpeg
3D Max 2025.3
Windows 10 22H2
Ryzen 5950x
64GB Ram
