Tydiffusion v1.125 comfyUI installation failed
Hi, i tried installing ComfyUI Tydiffusion v1.125
but installation is failing.. in the maxscript listener its showing
tyDiffusion installation error: Setup command line batch process closed prior to engine connection test.
plz help me i am desperately searching for solutions since last 1 month and have searched every nook and corner of the forum... but its not installing..
also i've tried previous versions but no success.. every time a new version is launched i hope it gets installed but sadly same error is occuring while installing.
Plz help me.. Sad
Also attaching logs. pllzzzzz need this to be solved ... huge fan of tydiffusion.
.rar   logs.rar (Size: 2.44 KB / Downloads: 128)
You didn't attach the logs...you attached the batch files.
(03-23-2025, 01:51 PM)tyFlow Wrote: You didn't attach the logs...you attached the batch files.
where to find the logs?
