03-24-2025, 05:24 AM
tyFlow v1.126 is up!
https://pro.tyflow.com
* Display operator custom float and velocity magnitude color modes can now be remapped to a gradient
* added custom float/vector prefix toggle to PRT export in Export Particles operator
* Birth PRT and PRT Update operators can now load unrecognized channels as custom floats/vectors
* added invert option to Shape Remove operator's material ID list
* added Bifrost naming preset to Alembic point cloud settings
* fixed an issue where tySelect noise modes would not animate properly in some selection modes, if frequency was not 0
* re-added toggle in Cloth Bind operator to inherit material ID overrides of driver particles
* fixed an issue where duplicating a flow would delete Value operator connections in the new flow
* fixed an issue where copying and pasting operators connected to Value operators could not retain Value operator connections
* fixed a regression where pressing the top-right "refresh" or "enable/disable" buttons in the editor would deselect any selected operators/events/etc
* fixed a regression where setting a Birth operator's start time to a negative value could cause particles to disappear until the sim was refreshed
* fixed a regression where trying to enable/disable multiple selected operators or events wouldn't work
* fixed an issue where the Export Particles operator could freeze in object export mode in some situations
* fixed a regression where custom property filters were no longer working correctly
* fixed a rare case where the tyCache modifier could crash while caching
* fixed an issue related to how Value operators read custom float values
