05-25-2025, 11:58 AM
Ever since the new noise system was added a while back i've never been able to get the same results when it comes to curl noise. I used to select Curl and the particles became very stringy and and seemed to stay on a fixed path. The curl perlin noise gets close but the results seem to animate and overlapĀ despite there being no frequency or phase enabled.
Image 1 is correct, where they all stay curling around the same area consistantly
Image 2 is where it's at currentlyand it seems to overlap with time and expand becoming messy.
Am i just doing something wrong? because it used to be very simple and easy. the first image is from a tutorial i used to use which now doesn't work in the same way because i can't achieve the same result with noise.
