Mirrored Objects Orient Surface Negative Normal
If you mirror an object the Surface Orientation node will treat the surface normals as inverted and scatter objects inside instead of outside the object.
.max   Mirror Scatter Normals.max (Size: 712 KB / Downloads: 95)
Negative scale values can have all kinds of weird side effects, inside and outside of tyFlow - just reset the scale and/or xform on your mirrored object.
