08-01-2025, 03:24 PM
tyFlow v1.130 is up!
https://pro.tyflow.com
* tyVector texmap renamed to tyValue texmap - added support for reading instanced particle properties (VRay CPU), and new ways to adjust output values
* added PhysX bindings count option to Display Data operator
* Pack operator result no longer as sensitive to input particle order or position
* fixed an issue where Position Raycast operators would load as Pack operators (Pack operators saved in existing files will need to be replaced, as they will load as Position Raycast operators)
* fixed an issue where switching between tyLibMtls would leave hanging texmaps in the SME
* fixed an issue where Multifractured particles meshed with a tyMesher would be improperly offset
* fixed an issue where cloning a tyMultifracture modifier wouldn't clone its saved paint strokes
* fixed an issue where the tyConform modifier could crash during file load in some situations
* fixed a regression where the CUDA help and compatibility buttons in the tyFlow GPU rollout were not functioning
* fixed a plugin-wide issue where meshes with vertices but no faces could cause viewport display artifacts
* fixed an issue where the transform monitor used in certain tyFlow modifiers could cause issues during file reload
* fixed an issue where PRISM could generate indeterminate results when processing coincident triangles
* mitigated a regression where Branch operator would always integrate velocity of new particles by adding toggle for that feature
* "Show incompatible" will no longer need to be checked in the material/map browser, in order to show tyFlow materials/texmaps for all renderers
