disable during render
i know we can disable flow, or have it as "render only", can we have it as "viewport only" , and not at render time.
often have phoenix sims that use tyflow particles, but when I hit render, tyflow updates, even if its not rendering anything
cheers
Harv
If you have a render-only param that is causing a dependent flow to reset and you want to avoid that, you can just set flow reset mode to manual from the editor right-click menu.
thanks Tyson Smile
