Cloth bind and mapping/Inherit mesh UVWs
Maybe a misunderstanding on my part, but I basically see Cloth Bind as a combination of particles and a mesh that is attached to them.
If I don't use "Inherit mesh UVWs" in the Cloth Bind or a Mapping operator, the UVs of the mesh make it through the process fine, the output mesh is basically the input mesh.
But if I use eiter of those options because I need the mapping to drive something, the mesh UVs get mangled at (fused across) seams in the UV, likely a projection error, understandable in case of the particles as they don't know which side of the seam they belong to.  What I'd expect/wish for, though, is that the projection only affects the particles and that the original UVs of the mesh remain untouched or are restored after the fact. Or have a checkbox in case someone really wants to project mapping from a different mesh to the mesh itself.
One workaround is to use a second mesh that then is wrapped/skinned/bound to the first one, or copy the uws manually, but that's a bit cumbersome (and like said, in my mind, the mesh is already bound to the particles to begin with).
Basically, an equivalent to the already existing "Inherit particle mat ID overrides" checkbox, just for UVs.
