PhysX Break by Bind ID + Frame Range = Maybe
I'm running into an issue in a fairly complex flow with several different sim groups and physx bind IDs where a physx break with Filter by ID on does't work (no break occurs) when used in combination of Frame Range timing set in the break operator.  If I use a frame range timing on my existing test (distance, etc) that triggers the event containing the break op, and have that break op set to Continuous...then it works.  I've tried to replicate the issue in a simple scene but it appears to work if you just two a couple of Birth Shapes/PhysX Shapes/Bind/Break.  If needed I can try to make a stripped down version of my problem scene and send your way.   Thanks.
Quote:If needed I can try to make a stripped down version of my problem scene and send your way.
Yes please. Send to support@tyflow.com.
