Find target issue
Question
Hi, i am following a YT tutorial to setup a find target flow.
The video is a few years old so perhaps things have changed drastically.
But to my knowledge the setup I have created thus far should work, but you guessed it, it does not.
When I use a custom TM name, the source particles are moving somewhat to a target, but still no go.  Huh
Is there anyone able to take a peek at the attachment and see why it is not working?
Much appreciated!!
best
Menno
.max   find-target.max (Size: 940 KB / Downloads: 183)
Everything in your setup is fine - the only problem is the event evaluation order. Your target particles are born after the particles targeting them, so no targets are assigned.
Click Event_003 and boost its priority. You can see the evaluation order by enabling its display from the editor right click menu. You want Event_003 to evaluate after Sim-group-2.
Aha thanks Tyson!!!
I was lowering the number thinking a lower number meant higher priority :-S
But increasing it did the trick.
