How to make tyFlow cloth behave like rigid plastic wrap (not fabric)?
Hi everyone,
I’m simulating a thin sheet being peeled off a container with tyFlow cloth.
Most of the behavior works fine: the sheet sticks to the container at first and then peels off as the robot lifts it, which is what I want.
The only issue is the final stage: once the sheet is fully lifted, it still behaves too much like hanging fabric, forming soft folds.
Ideally, I’d like it to look more like a rigid sheet of paper or plastic wrap – keeping its shape with sharper creases instead of draping like cloth.
Any suggestions on stiffness settings, solver choice, or mesh setup to achieve that rigid look after lifting?
.mp4   TAB-NEST-SYRINGE-PELLICOLE_Perspective_preview_v001.mp4 (Size: 11.42 MB / Downloads: 8)
Maybe an easy solution would be just adding slow operator, and in it's timing option, enable at which frame you want to be activated.
Yes, I already placed one that starts in the uploaded video around frame 100; it works. Maybe I will increase his percentage. In the end, the robot drops the paper in a bin, so probably no one will notice anything unpleasant
