MB with Splines
If splines are constant I can get MB
But when the splines change in quantity I cannot.
I thought TyVertexVelocity was meant to fix this creating some kind of aproximation?
Strangely enough it shows the right velocity vectors in the modifier but Vray just wont take it.
is this a Vray or a Tyflow issue? or it is expected?
Thankyou!
.mp4   Ignacio Capture 2025 09 27 09 27 29.mp4 (Size: 2.09 MB / Downloads: 174)
.max   splines_MotionBlur_001.max (Size: 884 KB / Downloads: 223)
I'm not able to check the file at the moment...is your VR moblur interval center set to 0, so that the center of the moblur interval is a whole frame? Please check the tyVertexVelocity modifier documentation for more info.
(09-27-2025, 02:45 AM)tyFlow Wrote: I'm not able to check the file at the moment...is your VR moblur interval center set to 0, so that the center of the moblur interval is a whole frame? Please check the tyVertexVelocity modifier documentation for more info.
Yes I tried that too, sadly no luck.
I've been investigating every option and documentation, but I'm failing to understand what I'm doing wrong.
Or maybe is how is supposed to work?
So far my workaround is to create all the splines at the begining and to not alter the number of vertes or anything about that.
That way I can use MB, not ideal when I have lots and lots of them but at least works for me Smile
Thankyou!
