04-28-2019, 10:45 PM
New version is out!
http://beta.tyflow.com
* Script operator can now sample texmap color values
* Baseline operator has options to exclude display/mesh/etc operators
* Collision operator has pass-through option for controlled particle leaking
* a tyCollection helper object has been added. You can add multiple objects to it, then add it anywhere in a flow and it will pass all of its objects into the flow. It makes multi-object management much easier.
* preliminary support for Alembic export added. Particles can be exported as Alembic point clouds. Mesh export is still on the todo list.
* fixed issue with particle birth/death scale up/down in tyCache which was causing particles with a lifespan of 1 frame to be removed instantly after birth
* fixed an issue introduced in v0.16015 where tyCaches were not rendering when VRay motion blur is enabled
* fixed a bug where tyCaches weren't properly displaying mapping overrides even if "ignore UVW overrides" was disabled
* fixed an issue where tySplines object properties were not displaying properly in the track view
* fixed an issue causing tyFlow to immediately crash when created on machines with CPUs that do not support SSE4 instruction sets
* fixed a crash when doing a 'surface area' property test
