Sorry me again, I'm not sure about this one, and I already found a workaround here too, so no worries, but thought to report it just in case.
I noticed that Particle Bind ”Bind Siblings” + "Bind to parent" + "only if first child"
and the Spline "Siblings" + "connect to parent" are not the same?
I tried it in the video and as you can see, the spline never connects to the parent.
If I switch to parent mode then they all connect to the parent... so seems the "Spline Paths" can see the parent but not when on sibling mode.
Is this expected?
so far the a couple of workarounds are, to use Particle Bindings ( but noticed it is slower when exporting seems )
and create just another binding that attaches to the desired group of particles, in this case the "parent"
Thank you~!
Is this expected?
Thank you~!
