10-12-2025, 03:17 PM
tyFlow v1.132 is up!
https://pro.tyflow.com
* added additional influence parameters to tyVortex force
* tyDiffusion should now be compatible with RTX 5XXX GPUs (note: you may need to delete the C:\ProgramData\tyFlow\tyDiffusion\Tools\ folder, and then re-run the one-click installer in order for 5XXX support to work)
* CCCS can now run without the supplemental tyFlow CUDA DLLs (albeit, slower). CUDA DLLs no longer a hard requirement for CUDA support throughout tyFlow
* optimized how tyCache Deadline export works when exporting multiple operators (fewer confirmation popups will appear)
* fixed an issue where the relative-to-property "invert" checkbox was not working in the PhysX Bind operator, in legacy scenes
* fixed an issue with loading an Alembic file containing custom vector properties into a tyCache
* fixed an issue that could cause the tyConform modifier to crash when conforming material IDs
