HI
How do I create RGB position displacement?
The Position Displace alone doesn't let me set the normal direction so its only displacement in one direction.
I want to add the "custom Property set the initial position" of a Birth Voxel grid
to a sampled 3D mapĀ
to offset position from the initial point to the RGB value continuously
So that the particle remain anchored to their initial pos but sway to the RGB map. RGB displacement.
This was simple in PFLOW with the data operator but I cannot figure out how to do this in TYFLOW.
Any existing mapping tutorials appreciated or what do i use instead of a data operator?
thanks a lot
Remi
create birth vox
save initial pos
send out
position reset
vertex color sampleĀ
set vertex color
add initial position xyz to a get vertex color rgb vector
thanks a lot
Remi
create birth vox
save initial pos
send out
position reset
set vertex color
