Spawn by Travel Distance
I'm trying to reproduce this tutorial using Tyflow pro (https://www.youtube.com/watch?v=rwwH_Z_mgvc) but I'm stuck with the Spawn by Travel Distance function, i can see som particle in step mode but not in travel.
I'm really following the tutorial step by step, but I can't understand why it's not working.
Do you have any idea, or maybe a screenshot of your TyFlow setup?
best regards
Set your timing to continuous in the spawn operator.
First versions of TyFlow did that sort of automatically in spawn op (this is why it worked in Allan tut, without changing).
(11-13-2025, 03:52 PM)d4rk3lf Wrote: Set  your timing to continuous in the spawn operator.
thanks you so much!!
