vertex color help
HI
Im struggling to get ty vertex color to show in my renders, for weeks now.  AI has not solved it so Im back here again.
https://limewire.com/d/xIs8k#jIJsBbZjZI
I can see my particles using the map correctly in the viewport but in render they each have the whole map.
I have the same mapping channel using 3dsmax default vertex color map. Whatever i do makes no difference whether its using the ty vertex color at all, any mapping setting before or after it or if i use it with the vertex color map.
I cannot see any user example files that just take the color applied to them and sample it locally.
Can someone please explain or share an example where the render shows the vertex color texmap?
I would also like to use this same rgb data to drive other things via a custom channel but that for later.
thanks a lot remi
Also is there any documentation for tyTerrain?
Maybe I'm missing something (feel free to share a file, saved back to the oldest max version possible), but once your vertex colors have been set, the Vertex Color map should go directly into your diffuse/base color map for your render material.
