Mapping perfect in viewport, not in render.
I have a sphere with a texture map that's hidden.
Added a tyFlow Birth Voxels to that sphere, with shape and mapping operators, and a delete to remove particles after each frame.
Animating the birth size I get this. A voxilized logo with increasing resolution as the cube particles shrink, like a 3D pixelation effect. It's exactly what I want...
But only in the High Quality viewport.
When I do an actual render, I get this. An image where every cube particle is lovingly textured with the complete logo. Exactly what I don't want!
I can see my heart's desire right there in the viewport, but it's out of reach when I render. How can I fix this?
Denis Loubet
Maybe a second mapping operator might do the trick? Or you can bake the colors to vertex colors and use those for your material in case it's a bug or a quirk of your renderer.
An example file might help (saved back to the oldest max version possible).
(12-05-2025, 03:06 PM)Findus Wrote: Maybe a second mapping operator might do the trick? Or you can bake the colors to vertex colors and use those for your material in case it's a bug or a quirk of your renderer.
I tried another mapping operator and that didn't work, but on a lark I switched renderers to V-Ray and lo and behold it rendered it in all it's solid-colored-cube glory.
I don't know which renderer is technically doing it right, Arnold or V-Ray, or if Tyflow is to blame, but V-Ray gets the WYSIWYG prize!
Thanks for your help! I hope someone else can benefit from this thread.
--Denis
Glad you figured it out!
