Terrain Snow
Is it possible to reduce the snow thickness in the current version of Terrain Snow using keyframes? I tried doing this before, but it didn’t seem to work.
Yes, also make sure you set your flow to history independent.
Thank you for your answer. I'm a beginner and just started learning TYFLOW. Could you please provide a guide on the correct setup process? I would be very grateful.
See attached.
.max   snowAnimated.max (Size: 656 KB / Downloads: 147)
(12-02-2025, 04:07 PM)tyFlow Wrote: See attached.
Thank you so much, I will be very grateful.
I have another question. For example, I've animated a mountain, and I want to export the cache. Which operator should I use, or can I use the Export Particles operator to do it?
I have another question. For example, I've animated a mountain, and I want to export the cache. Which operator should I use, or can I use the Export Particles operator to do it?I have another question. For examI have another question. For example, I've animated a mountain, and I want to export the cache. Which operator should I use, or can I use the Export Particles operator to do it?ple, I've animated a mountain, and I want to export the cache. Which operator should I use, or can I use the Export Particles operator to do it?
