Unexpected binding stretching
I'm trying to figure out why these particle binds stretch for several (10-13 or so) frames before the rest of the particles begin to follow?
These particles are imported from another flow, updated on event entry only, and bound together with particle binds.
When they collide with the fingers they are object bound to the fingers with lock to surface enabled and a particle switch to deactivate bindings.
I know I've successfully done this before and failing to see what I'm missing this time.
(12-13-2025, 09:07 PM)ssbuchan Wrote: I'm trying to figure out why these particle binds stretch for several (10-13 or so) frames before the rest of the particles begin to follow?
Try placing the Pswitch before the Object Bind operator? Also check that your collision test is working correctly, with no time offset.
