My first use of the Value Operator so maybe I have missed something. I want to change the Break Force and Break Torque values of the PhysX Bind operator after a certain timeframe. I have tried using the Filter rollout on the Value operator for this, but that did not work, and now I am using an expression on the Value operator to do this. However, PhysX Bind uses the true values past frame 690 and never switches to the false values of the expression. Can the values on PhysX Bind not be changed like this?
BTW, I tested this same value operator expression logic in another test flow, linking the value operator to the birth amount, and that method works. Also tried just keyframing the values on PhysX Bind, and that did not work either... whatever the values are at the beginning of the simulation is what's used to the end... no reflection of changed values.
thx
thx
