Pack operator crash
When using the Pack operator, setting the padding value to 17 or more (on any meshes), causes tyFlow 1.133 to crash for us.
Thanks, I'll look into it...
I tried with a simple setup all the way up to padding of 100 and couldn't reproduce a crash.
Please post a file where it happens and/or the crash minidump as well.
Please find attached file and minidump.
In order to make it crash, I enabled Array modifier on the Teapot, and then play with the Pack settings, things like changing rotation, pack size etc.
It happens sporadically so I can't pinpoint exactly what causes it.
Thank you
.zip   packOperatorCrash.zip (Size: 1.72 MB / Downloads: 159)
Hmm, yea...still can't repro and the minidump doesn't reveal much.
I set padding to 50, enabled the Array modifier, and wrote a script to reseed the operator 100 times - still no crash.
If you find a scenario where the crash is repeatable every time, let me know...
In case its a thread race-condition issue (hardware-related), you could try disabling multithreading in your flow and see if you can still repro the crash...
