tyFlow v1.133 tyCache does not render on some render nodes
I have tyFlow system which brakes objects apart and with Physx simulation. I exported this simulation to tyCache and made preview. Everything works fine. I sent file to render on 6 render nodes via Deadline. On all render nodes I have tyFlow_2026_render.dlo installed (from 11/20/2025). Four render nodes render fine, but two render nodes do not render cached particles, like they are missing. I cannot figure out why two render nodes do not render cached particles. I use 3ds Max 2026.3.
Update. I tried to render only tyCache particles by selecting tyCache object and changing VRay render to render selected. They do not render on workstation, I see only completely black rendered frame. It looks like I can only fix this by re-rendering all bad frames in full frame using only render nodes which can render them. What a mess. I previously rendered such setup in Max2024 without any problems.
Load UI Max on the problem machines and try rendering with regular tyFlow - that will determine whether it's a machine configuration issue (ex: they can't see the shared path where the tyCache is stored, or something like that).
I tried to render with UI on problem render nodes. It renders fine. But it doesn't render without UI. I have no clue what happens. I previously rendered similar setup in Max2024 and tyFlow 1.132 without problem. Now I render in Max2026 and tyFlow 1.133 and have a problem.
On your problem render nodes have you looked at the vray log or 3ds max log to see if anything pops out? I imagine deadline has some sort of log as well. I have had similar issues before, and it usually boils down to a path issue.
(01-28-2026, 12:33 PM)leejk Wrote: On your problem render nodes have you looked at the vray log or 3ds max log to see if anything pops out? I imagine deadline has some sort of log as well. I have had similar issues before, and it usually boils down to a path issue.
That is the a problem that logs file do not show any information which could give an idea about issue. It just looks like tyFlow plugin doesn't initiate on few render nodes. I have not figured out the problem yet but I am going to render similar scenes soon and will have to look at this issue again. Maybe I will be able to gather more information.
